I'd like to lower my cruising RPM. 6-speed transmission is nice but too much expensive and much shifting furthermore.
How many teeth does a stock Twin Cam 88B compensating sprocket have?
Is it OEM 40308-94 with 25 teeth?
Is there a 25 or 26 teeth compensating sprocket available or do I have to make it myself?
Stock is 25 comp. sprocket 36 clutch basket
Baker makes all kinds of sprockets up to 28 tooth for their DD6 gear set. Very likely you'll need a chain as well to make up for the sprocket size, several options of chains available. Not a good idea to go to a taller gearing if you don't have the low end torque to push the bike forward. Your avatar signature says "mountainrider' What's up with that in the context of your question?
ViennaHog:
I like mountains (riding, hiking). Not too high here but let's say... Alps, Dolomites?
I usually cruise around 80km/h. I hate riding on the highway above 110km/h when RPM seem too high and I'm looking for the 6th gear.
I have 2004 FLSTCI, 1450 ccm, Stage I Kit (SE Air Cleaner) and V&H Big Shots Long pipes, Stage I Kit modified map in EFI. You're right I would probably need 1550 Stage II Kit not to exhaust engine with increased compensation sprocket teeth count.
