I am currently installing a 95 BB kit and purchased the Cometic engine overhaul kit. The instructions advise to eliminate the cylinder head alignment dowel o-ring. When removing my cylinders I never had an o-ring on the cylinder head dowl. Are they saying to eliminate the small o-rings on the bottom of the jugs over that alignment dowel? If so what will keep it from leaking oil. The kit never included the small o-rings for the dowels in the case. Thanks for your help in advance.
2005 RKC
Administrator
Use the O-ring between the case and the cylinder. Not between the cylinder and the head for most 95" head gaskets.
