· Registered
09 Night Train, I just did a big bore kit and put in the Screaming Eagle Clutch Spring. I adjusted it the same as always, twice now. I pull the lever and it disengages partially but if I have it in first and lever pulled in and pick my feet up it will start to roll, cant shift into neutral unless rolling, what am I missing here, would like to get this straight so I can get the break in done
· Registered
Try turning adjuster bolt out only 1/2 turn and mimimum allowable play at the cable end. Also , you might be better sattisfied with the 103 spring, plenty of grab but easier on the hand, not as hard to pull.
· Registered
I tried half and 3/4 no difference, I figured at half turn would be the least amount before the adjuster would make contactand in turn push the clutch further apart to disengage but that didnt work either
· Registered
I have the Diamondback Braided Harley Clutch cable it looks like the bottom side where the adjuster is has unscrewed where its crimped so Im assuming this wont allow it to adjust correctly, so Im assuming I need to put the stock cable back on. Is there anyway to fix the cable or is it done
