No, have had no problem with Syn 3 or Amsoil 20-50
CT Rich said:Has anybody else experienced clutch slipping after they've switched to SYN 3 lubricant in the primary case?
Running Syn 3 in the primary with no problems.CT Rich said:Has anybody else experienced clutch slipping after they've switched to SYN 3 lubricant in the primary case?
How many ounces did you put in?CT Rich said:Has anybody else experienced clutch slipping after they've switched to SYN 3 lubricant in the primary case?
Don't know what year you got but I was told by my dealer the other day that there is a voluntary recall on all 2006 six speed transmisions because of this very problem ( slipping into gear from neutral while idling).CT Rich said:Has anybody else experienced clutch slipping after they've switched to SYN 3 lubricant in the primary case?
Nearly 7 1/2 gallons? The oil tank is larger than the gas tank? Could this be a typo and you intended to say milliliters? My '05 TC calls for 24 oz. (0.71 liters) in the tranny and 32 oz. (946.35 ml.) in the chaincase.bbq-n-beer said:Doubt if the oil is the problem,did you put in no more than 950 ounces??
Would say it need's an adjustment.......run syn 3 in mine with no problem's.
