OK, so I am in the middle of my engine swap from my all ready built up 95" to a 120R so I figured I would put this thread here. As I was preping the primary side and draining the oil I noticed metal peices comming out, not to large but figuring that it was the ring gear...well to make a long story short, it landed up being the clutch hub spline teeth that slip on the transmission main shaft. The main shaft is fine. the edge closest to the tranny have about 8 or 9 teeth chiped. Also I noticed that the hub moves around a little while it sits on the shaft with out the hub nut installed.
What caused this?
I will get pictures as soon as I can
What caused this?
