Just bought the HD reduced clutch pull kit and it requires the replacement of the diaphragm spring. The service manual states that to replace the clutch disks, same basic concept, you need to remove the outer primary cover. When I look at the size of the spring compared to the size of the derby cover it appears as if I can replace the spring by working thru the derby cover opening without taking the primary cover off. Can anyone confirm that I can do this?
TIA,
Danny
TIA,
Danny
