1 - 2 of 2 Posts
Looking at the service manual for putting the clutch back together and it states....
1. Install the narrow friction plate on the clutch hub. Engage tabs on plate with the slots in clutch shell.
2. Install damper spring seat on clutch hub. It must sit inboard of narrow friction plate.
3. Install damper spring on clutch hub with the concave side out.
4. Install a steel plate.....
What is the order of pieces that go into the clutch shell?
01
Morning guys!!
The frictions and steels( after you follow the book) are the same friction disc to steel. So no order, does that make sense?? If not call me I will walk you through it easy stuff.
1 - 2 of 2 Posts
