1 - 17 of 17 Posts
I have stock Alloy wheels on a DYna ... They are the black and silver ones and now are pittting and the will not come clean no matter what?????
Please help me clean my wheels
If they are pitted then there isn't much you can do except polish them. The pits are the brake dust eating into the wheels. I use Simple Green to clean mine and it seems to do a more than decent job.
later,
KrustyTC
I found for cleaning my wheels and for that matter even aluminum cases. (use to detail old triumphs) I use Eagle #1 It's auto aluminum mag cleaner. They have 3 types. But Eagle #1 is for aluminum wheels that don't have a clear coat on them. You just spray it on and it doesnt harm your paint or chrome. It will foam up white and then just wash it off with a hose. Cases clean up like they just came out of their mold. Providing you degreased them before this application. On the wheels, after washing them off and then drying. I use (not sure of the spelling) Zephor 40. I green cream polsh. You can apply this polish in the sun. It turns white like mothers polish. but isn't a mother to get off. Actually it comes off with ease. This polish will bring the aluminum back to a chrome like finish.
On the (smooth) black painted area of my mags. I use a HD product. Its the #2 plexi glass polish. I use it as a polishing compound. It will bring the black back to looking like you cleared these sections of your wheels.
zoood/ RJ
I love BIG headlights...
Eagle One is the best wheel cleaner I have used, I have the natural engine I use it to clean that as well, best thing I have found and it's cheap.
01 FXDXT / 75 FLH
Clear Coat Question on Stock Mags
Do the 2001 Dyna's with the mags have a clear coat on them? I would like to know before I try any remedies.
ride hard
ride hard
As far as I know. Non of the mags on any models have a clear coat on them. Honda did that to theirs, years back. Even if you use the Eagle one on a clear coated wheel. No harm will come to the clear coat. Eagle product do have #2 & #3 for clear coated wheels. But as i stated before. I don't believe they clear their wheels at all. To check it tho, in an area that one wouldnt see, like the lil edge at the tire bead area. Just take a lil aluminum polish on a cloth and rub it a little. if the rag gets black. The mag isnt clear coated.
zoood/RJ
I'll second simple green. I have a Night train and the rear wheel was going to hell.
Tried a couple of products - Sprayed on some simple green and used some fine steel wool - Not like new... but I'm happy with the results.
Stock Wheel Polish
I also have the stock black and alum. mags on my bike. The key is keeping them clean...however; if they do get stained, or pitted, you may be able to clean them up. Try any good metal polish..ie..Mothers, Blue Magic, or even the H-D metal polish. Clean them good, then start polishing. I have spent 2-3 hours polishing my mags to a good shine. If your rims are in bad shape it could take longer. Try whatever flavor of polish on a small spot first. You can also use very fine steel wool(0000), or sand paper(very fine grit) on the worst spots. Again, test each method first. Then, Keep them clean.....Good Luck....
1 - 17 of 17 Posts
