I switched to a higher output bulb in my 06 Ultra from a 50/55watt bulb to a 90/100watt. I noticed a film on the inside of the the light housing. I tried using a paper towel and wooden dowel rod to wipe it out with minimal success. I am thinking maybe some rubbing or denatured alcohol, what have you used that works inside the light housing.
Alcohol, then rinse with water, and it will come out... ;)
That is what I tried it worked fine
