21 - 25 of 25 Posts
· Registered
1945 HD UL, 1948 HD FL, 1991 HD FXLR, 2007 HD FXDB
I wipe the painted canvas lightly before spraying, although I haven't achieved glass because I paint poorly. Done the tanks a dozen times, she's close
Is this spell check gone horribly wrong?
"painted canvas" - ???
None of my bikes have any canvas parts.
"achieved glass" - ???
· Registered
My go-to recipe for cleaning chain grease is to combine equal parts warm water and white vinegar in a bowl. Soak the chain in the solution for about 15 minutes, then scrub with an old toothbrush or stiff brush to remove any dirt and grime. Rinse the chain off with clean water and dry it completely before re-oiling it.
· Registered
2004 Street Pro S&S twin v 124. Baker 6 speed
Discussion Starter · #23 ·
What’s your favorite chain lube?
· Registered
I'm a bit skeptical that a lukewarm mix of warm water and vinegar would act a solvent for grease in a chain. As I recall, the old-time HD service manuals recommend cleaning the chain with gasoline, and then soaking it in motor oil or even axle grease that's been heated to make it melt some. After the chain has soaked up some of that grease, wipe it down with a clean cloth. Of course, it probably wouldn't be good to heat up chains that have rubber O-rings...
21 - 25 of 25 Posts
