Just bad
Yes - actually asking before tearing something up :) what a concept!
I am currently re-sealing the left side of my '01 RC. Between the monkey method with the new parts and the parts & service manual, most of the work is pretty straightforward.
The one thing the manuals aren't real clear about is the location of the quad seal. If I slide the drive sprocket spacer off of the mainshaft I can see a strip of rubber against the drive gear. Is that it? It looks close to the same as the replacement but...
Before I start digging around in there with picks to pull it out, I want to make sure I'm going after the right thing and not shredding a seal that will require a tranny tear-down to replace.
Thanks in advance!
Just bad
Discussion Starter · #2 ·
No dice on the query here so I did proceed carefully, being ready to start putting things back together.
I had guessed correctly - the strip of rubber against the drive gear behind the drive sprocket spacer was the quad seal pictured in the parts manual.
I figured I'd answer my own post just in case someone turns this thread up in a search at a later date.
Cheers!
