1 - 20 of 48 Posts
· Registered
Rode the bike to work this week and noticed this morning when I pulled up after 20 miles or so, I heard a faint clanking noise from the primary, even while in neutral. Never heard this before. Almost like there was something loose.
Left work 10 hours later. Didn't hear again until after 20 miles. I let the bike idle and could hear it again when listening around the primary area. I will inspect this weekend but thought I would ask you guys what you think it might be or what I should be looking for.
It's a 93 FXR. Any help or suggestions is appreciated.
I know I may have posted this in the wrong place. But I just wanted help from the FXR boys. :D
Let me add that you don't hear it at full speed. Just when slowing and down shifting, say around 10-15 miles per hour.
· Registered
It's the compensator nut come all loose on ya. If the bike is kinda shimmy-ing and surging while this is going on, it's because the rotor is clanging around into the alternator too.
:boom:
:boom:
:boom:
· Super Moderator
If it will make the noise on the stand, take a wooden dowel and listen to the noise by touching the case at the same time you hold the other end of the dowel to your ear. You might be able to locate it front to rear. You can also listen to the cam cover, comp clatter will travel through the crank and be audible in the cam cover.
· Registered
Discussion Starter · #12 ·
Yeah it makes the noise just running idle. I hear it more up front on primary side. I'll try the wooden dowel trick as well. thanks.
· Premium Member
I don't mean to cry wolf, but I had a noise that would come and go and just knew it was coming from the primary. Used the poor man's stethescope and listened all around it, but couldn't hear anything unusual. Of course it wouldn't make the clanging noise while doing this. Tore the primary cover off and found nothing out of whack. Put it back together and rode it down the road and after awhile the noise started and didn't go away, plus I had a dead miss. Then was when I tore into the cam chest to find the totally destroyed lifter roller and flattened cam. Just my experience with my FXR.
Just after trading for the 97 Ultra Classic, it started sounding like it was grinding gravel from the primary area. Pretty easy to diagnose that one because the volt meter was dropping. When I tore in to it, either a magnet came off the rotor or the screws holding the stator broke off. Autopsy was unclear as to which happened first but it sure made a mess of things.
From your symptoms, the primary would still be the first place to look because mine was making noise at varying engine speeds.
· Registered
I am guessing an issue with primary chain/adjuster at least that's an easy fix.I'm sending ya positive mojo.
· Registered
Discussion Starter · #16 ·
Hey, thanks for the positive mojo. Hopefully this weekend I will figure it out. Supposed to have snow so it's a good time to work on the bike.
1 - 20 of 48 Posts
