if you change your riser, which I dont see an option, what ya gonna do with your idiot lights? The dash on my new tank has three lights in it. One for generator, oil and high beam, you would use the generator light for your neutral light. You would need to put in lights for turn signal indicators.......................
Why do you need to use the riser extensions? Handle bars won't clear tank with out them? If so, then it may not be a issue with different tank. My new tank is lower profile than the oem peanut tank......and then without the speedo swinging on the bars, it gives you more clearance...........
How does your kick stand work, any reaon to put a longer kick stand on it?
