One thing I have seen even with low lift cams. I have then the rocker arm hit the cover in stock bikes, being that lids are cast they are going to have soem differences from one to another. THe problem becomes when a tech swaps a frontfor rear cover or vice versa. What I am saying is that you may have a slight clearance problem with rocker arms even on stock motor. I know they said they checked but it can be a very small area.
There are other things like piston slap, wrist pin bushing clearance out of spec, misaglined engine, broken front motor mount. List goes on and on. Chasing noise can be fun. Do you have any vibration at all that seems out of the ordianry??
Do the noise change with rpm??, at idle, NEED more info . :blink:
