I really don't want to pay $150 for a Stage I remap. All I'm interested in is raising the rev. limiter. Anyone know if there is a place that I could send my ECM to have the rev limit reprogrammed?
It's the map that determines the rev limit. You quit supplying fuel at 5800 rpm, or kill the ignition pulse, and the motor quits revving faster. If you increase the RPM limit for the ignition cutoff, and don't give it any fuel above the stock rpm, it still won't go any faster. The fuel and ignition maps are entertwined. To increase the rev limit, you have to install a new fuel/ignition map, IE Reflash.
Add another $200 to the $150, save yourself a bunch of headaches and just get a SERT to begin with. You'll be a lot happier in the long run.....
Ahh...I see....thanks
Yep, guess that's what I'll do...
