Ok l reset my TPS value to 0 in the PC Now I want to try another map.
Do you have to reset the TPS if you change maps or just upload the new map?
Hi, I only had to set it once and not again. I'm not sure what will happen if you completely unplug the PC and then plug it back in again, though.
Both the TPS and the Accel pump value are carried over when you load a new map.
Hmmm, brings another question to mind, but I guess if it hold the map after a power loss I guess it will hold the other settings?????:dunno:
