Becuase HD wants your money. Why would they suggest buying from someone else?V-ROD 1 FL said:This subject is always like discussing Religion and Politics.
My 1 cents worth is:
1. If Harley spent 5 plus years testing and evaluating the V-ROD and is willing to warranty it why would you want to take "the man in the street's" word for whats best??
When was the last ime you heard of a failure from another oil?[2. When is the last time you heard of a Harley motor failing because of using their oil?? And look at all of the motors they have on the road!!
Opinion3. If both products are reliable, and you are going to change it at the stated intervals anyway then it doesn't make sense to put a lot more money into an oil that is providing essentially the same benefits.
False rumor4. What are you going to do if you are on the road on a trip and need service at the dealership? MY UNDERSTANDING is that you can't go back to normal oil once you start using synthetic.
By law, you do not have to use thier oil.5. If a problem does occur with your motor, and HD does advise you that you're SOL because of your oil choice, it sure seems that the expense and inconvenience in attempting to get them to come around to your way of thinking would FAR EXCEED the value of using Mobile 1 in the first place.
Yep6. AFTER THE WARRANTY EXPIRES AND THERE IS MORE RIDER EXPERIENCE -- I say choose whatever oil "Float your boat".
Mind if I ask where?chiselchst said:I do not work at the Long Wharf...
VR-1 FL, I don't necessarily disagree with point number 1, but I think you may be overestimating HD's concern for your engine. I think the question being discussed here is what the LONG term affect of using a sythetic oil is vs. the HD citgo can. I won't pretend to know, but I won't take HD's word for it either. That's what this whole consumer oriented site is for.V-ROD 1 FL said:
That is mechanical not possible. Unless, your clutch was slipping before, in which case, I doubt your clutch would still exist.mnv-rod said:It also appears that RPMs are down about 100-200 at highway speeds
You ar not going to find that here.mnv-rod said:Let's be careful not to create an atmosphere in the bike discussions where people are afraid to post for fear of ridicule, ok?
Thanks!
