Chain Lube as General Purpose Lube?
850 Views 3 Replies 2 Participants Last post by  Ed Y
Anyone ever used motorcycle chain lube (like Bel-Ray) as a general purpose lube (for example, on hand lever pivots)? Thanks.
No reason it wouldn't work. Used to use it for lubing cables.
Mobil1 v-Twin in All Three Holes
If H-D SYN3 can be used in all three holes, what would be the difficulty with Mobil1 v-Twin, also a 20W50 syn oil, used the same way?
Depends on what additives are in it. That's a question that should be directed to Mobil. You really don't need anything fancy in the primary. Even ATF type F works fine.
