1 - 10 of 10 Posts
I have a 2000 Ultra. I bought it used last year. Last summer (my first with this bike) I got a lot of heat radiating up from the back of the engine. I just had the stage 1 95" kit installed.
I have read what I could find on ceramic coating and have decided to have my stock headers coated to reduce the heat from the rear cross over. I am not a hot rodder, but do not want to loose any of the bottom end (where I spend most of my time) by going to a true dual header.
Those who have had their header ceramic coated: are there any particular suggestions or things to watch for? I have looked around and decided to give Performance Coatings a try.
Any advice will be appreciated as this is a new venture for me.
Thanks,
Ken
I put A set of jokers on my train and the front pipe runs right under my leg with that ceramic coating you dont even notice the heat that much. Hope this helps
2005 Road King Classic
Thanks,
Ken
Ken,
These people are a lot closer to you.
http://www.jcmmachine.com/
Bill
Chris
Where are they in Pa.? Need the address for Jet-Hot.
Beaten to the punch again. Thanks wkohn. 95BadBoy, I used the website to get in touch with them. It has some good pics and info. My only advice is that if I were to do it all over again, I would have them only treat the outside of my muffler. Treating the inside reduces the inner diameter by just enough to cause problems. I pulled my baffles before I sent the pipes to them. Getting them back in once I got the pipes back was more work than I bargained for. I know that I will probably never be able to get that baffle out again.
Consider yourself blessed that you got them back in.
Thanks. I don't think they are to far from me. Will call them.
1 - 10 of 10 Posts
