Well i finally got my helmet and headset and put it together and went for a ride. Everything works ok, but there is "white" noise coming thorugh the earphones from the engine, it sounds identical to lifter ticking. It doesnt make any noise with the engine off, I turn the engine on, I can here it, and rev it up in nuetral and you can hear the noise through headset vary with RPM. I unplug it and it goes away.
Any ideas?
Bike is 06 Ultra
:thanks:
Chad
Well I tried my headset in the rear plug-in and the noise went away.
Im new to this Jim, what are the differences between the leads?
Both of them are brand new harley headsets.
Thanks again.
Chad
Another Old Fart
Any ideas?
Bike is 06 Ultra
:thanks:
Chad
Funny you brought this up, I was going to ask also. On my 05 Ultra, without the headsets I get noise when cb chatter comes in. It sounds like
the ignition spark through the speakers. Could it be unsheilded wires?
Not sure, any help would be appreciated....... Mike............
Don't know if this will help, as I'm not very up on the intercoms, but back in the day, my cb and stereos often needed a noise suppressor to get rid of what you are describing. You could try radio shack.
Fred
Sick Puppy
Try changing your spark plug wires,or you could re-route the front jack wires.It sounds like you are experiencing RFI emitting from your ignition system or plug wires.This can also be caused by using non-resistor type spark plugs , but if that were the case you would probably have noise from both jacks.
Another Old Fart
Thanks for the input guys............ Mike..............:cheers:
