When I joined the forum, I vowed I would not ask questions about the Trike because there are not many of us out there, and did not want to waste bandwith. I think I have found kind of an exception. Here is my question:
I had a Stage I done (Screamin Eagle Touring Pipes and air intake, and the obligatory re-flash) on my 03 Ultra. In hot weather, I get significant "popping" on decel and an occasional pretty loud backfire. I ask the dealer to check the plugs color and he says no problem. They suggested the bike is running lean, but would not cause problems. In cold weather, I get no backfire, but still some (but less) popping. OK, the question - can I ask the dealer to "rent" me a SERT or some other device and have them "rich-up" the fuel system (I assume this would be thru reprogramming the ECM), then test ride the bike to see if it helped? In other words, can a good tech tune the bike without a dyno? Maybe I should ignore the issue, the popping sounds kinda cool, but the backfire does not sound right. Would appreciate any suggestions.
Ride Safe.
Walt
Ride Safe.
Walt
