any body know if you can purchase the 02 sensor caps?
power comander dont have them
or will the caps from the automotive world work
thanx in advance
adlerx said:
Pretty sure all the o2 sensors use the same threads. Any muffler shop should be able to fix you right up
I think he's looking for the little electronic O2 eliminators that you use on 06/07 bikes to remove the O2 sensors since the PCIII disables them. You just plug them into the old O2 harness when you remove the sensors.
As far as getting the eliminators goes, if you can't get them direct from Dynojet I'd doubt anyone else is going to sell them. You might find someone that isn't using theirs they would be willing to part with, or you could always ask around and see if anyone knows how you could bypass them using just plain resistors from Radio Shack or somewhere.
Drel
You can purchase the 02 eliminators from Jamie at FuelMoto for 40 bucks, If not there, they are a 1 MEG resistor, as for the plugs from the sensors, they are 18 x1.5 mm, should be able to get them at a muffler shop.
talked to jammie yesterday
his words were they did not have them and were not getting any more
first time i have called them and the last
rude sob he was
not sure if it was because i was a shop or not
i got his number fron my drag rep
but even if they did have them i would buy from them
i know they use theese in the automotive world
and i know the sensors are pretty much the same
norrow band or wide band
just not sure if the voltage beeing sent to the ecm is the same
i am not a car guy at all and i am not getting help from the car guys around here
its really no biggie just trying to help a customer out is all
