I am swapping out a cam cover on my girlfriends 883. When I took the original cover off , 2 cams came with it. I understand that they need aligned for proper timing. I am assuming I need to remove the rocker boxes and pull the pushrods just to lift the tappets up and allow for the cams to be reinserted. Is this true? If so, is there anything special I need to know for removing the lower rocker box and pulling the pushrods?
Thanks for any help.
-Darin
-Darin
