I've decided I want to install Andrews 26 cams in my '03 fatboy. I'm going to be doing the work myself. I have yet to find a comprehensive list of what is needed so I want to know if the list I have is everything I need. I'm going to change the inner bearings to Torrington B-148s at the same time and also replace the cam chain tensioners. This list is assuming I'll have my indy press out the old cams/bearings and press in the new ones (can you use the oven method to remove the cams and bearings or is that only for installing them?). Here goes:
Parts:
17997-99A SE quick install pushrods
17045-99C HD cam installation kit
39954-99A Primary chain tensioner
39964-99A Secondary chain tensioner
11031 Tensioner retaining ring (2)
39965-99 Chain guide
17048-98 SE Exhaust gaskets
25938-00 Roller Bearing Spacers
LMR-002 Baisley spring
Andrews tw26a cams
Torrington B-148 bearings
George's Garage Tools:
Cam Tensioner Unloader TC88
Cam/Crank Gear Locking Tool TC88
Oil Pump Alignment Screws TC88
Inner Cam Bearing Remover/Installer TC88
Am I missing anything? Do I need to get any o-rings or anything else?
Parts:
Andrews tw26a cams
