Anyone know what would or could cause damage like this? The roller on the lifters show no damage.
As Jeff Foxworthy says,Bike sat 10yrs before I got it
Oops Bill Engvall!As Jeff Foxworthy says,
Here's your sign....
I have Never had any luck running zero clearance anyplace on any H-D engine.. I go by generous end of O-E recommendations..I did notice the wear marks were all to one side of the lobes which has me puzzled. Before pulling the cam out I checked the end play, none, I couldn't fit any size in, there was absolutely no play in the cam. Also when I removed the pushrods they were solid rods (non adjustable) and all looked the same length, however I cut them out so I really can't say in fact they were the same size. It seems odd to me that solid rods were used after a cam job. Last maybe the tappet/lifter blocks were not aligned, I don't think there is that much play in them though. I'll keep digging around I guess.
Had something very similar to that on a BSA I owned years back, after lengthy investigation it turned out it was just part of a 'dodgy batch' of cams that BSA had made. Not a lot can be done with it unfortunately... unless you have it 're-metaled' and re-ground. Having said all that ... if the bike wasn't used very often and only on short journeys... the condensation build up is enough to start eating away at the metal when left for extended periods! But that's in extreme cases in my experience.Anyone know what would or could cause damage like this? The roller on the lifters show no damage.
