1 - 2 of 2 Posts
ok going to the bearing house to get the torrington B-148 inners
can I buy the outers there also?? if so anyone with bearing #no.s
for chain drivecams
Thanks in advance
Highly Seasoned Rider!
for chain drivecams
Thanks in advance
I doubt that you will find the rear outer bearings in a bearing house. The outer front is a possibility but that rear bearing is proprietary. It also comes with a spacer and a miniature rubbber O-ring to center the spacer. I'd stick with Harley on the outers.
Harley sells a kit with all of the bearings inner, outer, O-rings and gaskets for a cam chest update. Only thing is the inners are the stock INA's. The Torringtons are available for about $2.50 apiece on the internet and at bearing stores.
Good luck,
1 - 2 of 2 Posts
