I have an 03 injected Fatboy with the Edelbrock 95" RPM Performer kit, stage 2 download, SERT, SE air breather and V&H bigshots. The bike runs well up top but lacks the low-mid torque and everyday driveability I really wanted. This Edelbrock cam is also running the stock cam chains. I think this cam it too wild and I want to go to a gear drive setup with roller rockers. The cam in the Edelbrock kit specs out at;
Duration @ .053" Open/Close* Valve Lift** TDC Lift
Int. Exh. Int. Exh. Int. Exh. Int. Exh.
246º 254º 20º/46º 52º/22º .619" .619" .188" .193"
The Edelbrock heads have 72cc chambers, 175lbs of seat pressure and are set up for up to .650 lift cams. The compression ratio they quote is 10.25 to 1
I ride 1 up and want lots of torque in the low to mid range. I don't care much about top end.
Any cam suggestions from you guyz is greatly appreciated!
