I put new cams in my bike and went to go change all three holes of oil when I went to go put oil in the engine I could only fit about 1 1/4 quart before the engine would overflow I found on other forums that if you remove the spark plugs pour a little bit of oil in the pushrod holes and then crank the engine for about five seconds wait 20 seconds and then crank it for five seconds again three times That the oil should pass through the crank chest and I’ll be able to add more oil to the engine is this the best way to prime the Cam chest? Sorry if this has been talked about before I’m new to the forum and just try to seek some knowledge
Try a bit of punctuation to make your post understandable. Welcome to America, use English.
How much oil came out when you emptied it?
If you could read I was doing a three hole change so everything was getting changed
That whole "three hole change" makes you sound like a rube. You don't change oil in "the holes", you change the oil in the primary, transmission, and engine; especially when you're trying to ask for help on the internet.
If I’m on here asking the question about the engine not taking the amount of oil it should and has every other time I’ve changed it don’t you think I have been through that step already?
How does anyone here know how many times (if ever) that you've changed the oil? How do we know you drained it correctly? Did you remove the filter and replace it or just pull the drain plug?
Removing the spark plug is a separate step from the push rods. You get to the push rods by taking the tube clip off and sliding the tube up so you can see the tappets. I don’t understand how it’s had to understand that I emptied the engine, looked in my clymer book to verify the amount of oil for the engine, went to fill the engine when only about one quart fit before overflow. I ask a question saying hey guys the specified amount of oil isn’t fitting and get told to use the specified amount of oil
That Clymer book is strike 2. Get a real service manual for your bike.
Since you don't seem to understand how this works, let me try to spell it out for you.
We can't see you or your bike. We can't hear you. We don't know anything about you or your abilities. We don't know exactly what you did to lead up to this point without you telling us. If you can give enough information (without being a dick about it) for us to paint a clear picture of your situation, then I'm sure we can help you out. If not, then go fill up your spark plug holes and crank away.
