73electraglide said:
I am in the market for another shovelhead, and I am curious about how hard it is to rebuild these engines. Once I get another bike, I want to put a low compression stroker kit into it for some more power. I have read that doing too much to a shovel adversely effects reliability, and that low compression is the way to go. What is a good balance for a bike that will pull pretty well and start every time? The bike will be an FLH. How difficult is it to put a shovelhead together RIGHT? I suspect there are little tips and tricks that veteran wrenchers use when building engines. Are there any good books out there?
TIA
Everythng that you could ever want to know about rebuilding a Shovelhead engine and other components is covered completely in the two 1978-1/2 service books for the FL's and the FX's.
Rebuilding any engine is not easy if you do it properly. It's very expensive to have machine work done. I have a stock 80" that has had a new crank, bore job and a complete cylinder head re-do with new seats, valves, guides and so forth. It runs great with low compression pistons. I really don't know how much more power you wolud like to have but IMHO, 4 1/4 inch stroke is plenty for one. If you stroke it, you may well have difficulty keeping the compression low enough to avoid pre-ignition.
Lots of folks go to dual plugs to avoid pinging but with my stock low compression bike I can run 75 mph literally all day and never overheat it. While stroking it may sound like a lot of fun, it's not the way to get a reliable engine. Higher piston speeds, more heat and the possiblity of detonation all work against you. Especially with an engine that has one of the poorest oiling systems ever put on a motorcycle.
If I were going to spend a lot of dough on a Harley and wanted to get the maximum poop for my $$$ I would probably concentrate on a Twin Cam buildup. They are reliable, even with big inches and can be made to go relatively fast.
And this is coming from someone who likes the Shovelhead very much. It's just that I like it so much that I want to keep it running.
You'll probably get a lot of other opinions from people who like to make changes but I still think the Shovelheads are better left stock, other than modern electronic ignitions, and better carburetors, etc.
My 2 cents.
