First off, I'm not the one who came up with this idea and it has been posted (reads: buried) in other threads. I just figured I'd post it as its own stand alone thread so others could benefit.
Below is the parts list for the Screamin' Eagle Stage I Kit for EFI Models (part #29773-02B). According to HD's web site it will fit '01-later EFI Softails, (except '05 FLSTFI 15th Anniversary), '02-later EFI Touring and '04-later EFI Dyna models. Does not fit '06 FLHTCUSE models with stock A/C cover. And retails for $139.95 ($108.71 at Zanotti's) not including tax and shipping.
The problem with the kit from HD is that its overpriced and comes with a crappy paper air filter, a gray back plate (that looks like crap on chromed or black engines) and a chrome/polished SE A/C Insert (the little donut that says "Screamin' Eagle" that you stick on the outside of the A/C cover) which also looks like crap on a black A/C cover (IMO).
Anyway, here is the parts list so you can build your own SE Stage-1 A/C (Poor Man's Edition) with a K&N Filter, proper back plate color/style and save yourself a decent amount of $$ in the process. Note, Zanotti's and Fox Performance prices can change and shipping/taxes will vary depending on where you live...
From https://www.zanottimotor.com/shopping/partLookUp.html
Just enter the part number and the quantity.
Part# - Quantity - Price - Total - Description
29478-05A - 1 - $9.66 - $9.66 - Gray Back Plate
29620-99 - 1 - $6.04 - $6.04 - Chrome A/C Insert (optional)
29583-01A - 1 - $0.83 - $0.83 - A/C Gasket
99642-97 - 1 - $5.68 - $5.68 - 243 Blue Loctite
29557-05 - 2 - $8.88 - $17.76 - Breather Plug
11292 - 2 - $1.16 - $2.32 - O-Ring
29447-99A - 3 - $8.13 - $24.39 - A/C Mounting Stud
3938 - 3 - $1.80 - $5.40 - Torx Screw
Total: $72.08
Then go to http://www.fox-performance.com/ and enter the part # HD-0800 for the K&N air filter. Should be $36.43.
Your total should be around $108.51 (not including tax and shipping). This will give you exactly what is in the SE Stage-1 A/C kit with a way better air filter and without the install instructions. The instructions are available in various threads on this forum.
If you have a chrome engine, you can swap the gray back plate (29478-05A) for a chrome variant (29510-05 for $31.36). Bringing your total to $130.21.
If you have a black engine, you can swap the gray back plate (29478-05A) for a wrinkle black variant (29586-06 for $27.24), and swap the Chrome A/C Insert (29620-99) for a black variant (29567-99 for $6.04). Bringing your total to $126.09.
To re-cap:
Poor Man's Stage-1 A/C + K&N filter = $108.51
HD SE Stage-1 A/C + K&N filter = $176.38 ($145.14 from Zanotti's)
Poor Man's Stage-1 A/C + K&N filter + Chrome backplate - Gray backplate = $130.21
HD SE Stage-1 A/C + K&N filter + Chrome backplate = $207.74 ($176.50 from Zanotti's)
Poor Man's Stage-1 A/C + K&N filter + Wrinkle Black backplate - Gray backplate = $126.09
HD SE Stage-1 A/C + K&N filter + Wrinkle Black backplate = $203.62 ($172.38 from Zanotti's)
Note: The Chrome (29620-99) and Black (29567-99) A/C inserts are optional. They're just accent pieces. They serve no functional purpose. If you don't want it, you don't have to get it, saving yourself $6.
Enjoy, you cheap bastards...
Total: $72.08
To re-cap:
