1 - 13 of 13 Posts
Ok I got a good deal on new brembo take off calipers. It’s the two piece rear and both fronts. So I’m planning to run them on the FXR
current set up I have is 2000+ Calipers with the adaptor bracket for the fronts and the rear is the solid one piece with a tab I welded to the swing arm. Rotors are 11.5 floaters. Ok time for the questions
1) can I keep all lines and both reservoirs?
2) do I need to change my rotors?
3) what fluid can I run? Running for 5 now
I haven't done this but I would think you can use same everything but the rotor. The compatible rotor mounting holes would have to be countersunk but I think they match up.
Did ecir45 do this? He might know.
you will need 11/16 master and 11.8 rotors. I would pull the pistons to clean the calipers out and run 5
Calipers are all being taken apart for new powder coat so new seals etc all around.
I have 11/16 master now since I’m running duals already in the front, just the old square box style haha.
Dam so new rotors are needed haha. Is that just the two fronts or the rear too?
We use to call the square box the coffee can.
Discussion Starter #10
Right. That might cover the cost of some of these fancy rotors out there
1 - 13 of 13 Posts
