I have a stock EVO on a '99 FLSTC. Recently,, at about 13,000 miles,, after never having any problem with my starting system (other than a new battery a couple of years ago),,, my starter began to spin instead of engaging. After learning that this was a symptom of a faulty starter clutch,,,, I removed the primary,, the jackshaft bolt, and then the starter. The jackshaft assembly was never removed from the case. I had my neighborhood alt/starter shop go thru the starter and repair the starter clutch. I re-assembled all on the bike,, making sure the jackshaft bolt washer was properly inset in the keyway groove. Everything worked fine for a couple of weeks of starting and riding daily. Then,, one morning when pushing the starter button,, there was a loud clanking noise in the primary side . There had been no indication of there being a problem on any of the previous starts the day before. After a couple of tries (with no change to the noise),, I removed the primary cover to find 2 broken teeth on the starter pinion gear. I found the 2 (whole) teeth lying inside,, cleaned all involved and replaced the pinion gear with a new one. All was fine once again,,, until about 3 weeks later (again, riding every day),,,,,,, it again has broken the teeth on the pinion gear. The problem is one that develops with previous great starts everytime,, and then all of a sudden breaking the teeth. As I said previously,, this is a stock compression evo. Any input of what may be causing this would be appreciated. Did I possibly,,, or my starter repairman possibly do something wrong? Or is there something else that may need to be looked at?
Good answer Mik, sounds like kickback.
Whether by kick back or low battery voltage, I've had to replace many 98 and 99 ring gear sets because of this type of breakage. The only complete solution I've found is the ring and drive gear set from Compu-fire. It's a hardened set that I've never had a come back or another starting problem related to the ring or drive.
