Huntray said:
Having a 95" build & SERT completed on my '05 Deluxe w/ +4K currently on it. Is there a correct or quick way to break-in as my Wrench states that I should put approx. 500 miles on it prior to Dyno?
Regards,
Huntray.
Hello Huntray...........definiteley a debatable subject on here if you go by past threads.......
Heat Cycles are generally for new bikes that have not been run before to de-stress the entire engine and get the cases, etc to achieve their final "set" position, however, it will not hurt anything if you want to do this even if you have only done a bore/head/cam change.
Some like to start the bike and let it idle until it has reached its full operating temp. then turn it off and let it cool down completely then do this again 2 or 3 times.
Others like me like to start my bike and gently ride it around for 20/30 minutes and then let it cool off completeley as this gets engine/trans/primary up to operating temp and in my mind achieves a more complete "set" at the interfaces of these components.
In reality your motor goes through the heat cycle every time you run it, but true heat cycling has improved engine life due to de-stressing the engine components in the first hours of any engines life.
As to which is the better way...........:dunno:
Break in:
In the first 100 miles, bring the engine up to 3000rpm max. through the gears to 4th gear................naturally, varying cruise speed constantly.
Try to stay at 3000rpm max for this length of time as this is the time that rings break if you push it.
100/300 miles..........once the engine has reached operating temp., start to bring the bike up in stronger pulls through the gears so that by the time you are at 300 miles you are doing hard runs up to 5000rpm or so.....again varying the speed at cruise..............this is generally enough for new cylinders and piston/ring kits.
I dont like to go hard in first gear until the bike has approx. 500 miles on it, as 1st gear creates the highest stress, in my opinion.
Rings achieve their full seal from this point up to approx. 1100 miles, dependant on how you broke her in.........and the cross hatch honing pattern degrees.
Incidently, while there are number of reasons why rings break, here are some common ways:
When fitting them over the piston you put a stress in the ring by careless assembly and this leads to ring failure.
You set the ring gap too tight, and in combination with the piston to cylinder fit.........the ring has no where to go when the engine heats up.
The honing process is not completed correctly and the micro surface has left too large a ridge surface which "grabs" the ring.
There was no oil film in the cylinders when the cylinder/piston/rings were assembled and the motor was run first up.
Cylinder Glazing and poor ring seal occurs when the engine has been run in too gently and instead of the ridges in the cylinders wearing in to suit the rings and vice versa, the ridges have folded over and trap oil which is burnt during the combustion cycle and now forms a hard varnish that builds up and causes blow by which results in poor performance.
All the best, Ozzie
