doing doing 104 build ,have b motor with chain conversion,was going to send my flywheel to King of cubes to get plug and welded or is there any thing else i should be looking at when cases are apart,opinions or suggestions please,thanks
How much hp are you shooting for? You may want to look into beefier connecting rods. Are you having Randy install a timken also? Randy is the man, he will hook you up with everything you need!! Its only $$$$!!
155" R&R TwinCam
You will be dealing with a pro working with Randy,he certainly can suggest what's best for the bottom end of your motor.
Id talk with Randy and see what he says. You can never be too safe!! Personally Id do it all (better rods, timken, lefty on right side, etc).
