Ok gang . 119.46 HP/108.01 TQ. The results are done. First and formost i want to thank Randy(Hyperformance) and Reggie(R&R Cycles) for their imput and combination to make these numbers happen. The dyno was done in a 5th gear pull. I have only a 5 speed.also i had the stock gearing in 3:15. The results are in true time. Also the altitude was 1,720 above sea level. I have done all things in real time and real results and if you understand these conditions. The motor still has more. All comments are welcome and thinking of going to Fla. to get even better numbers. after the final dyno . Wayne (Speeds Performance) did back up runs and still the same numbers. Wayne thinks that there is more in the motor but the air was not good enough to get more. Hope all can see the curve and the dang motor pulled to 6,400 RPM.Ok the motor is done and now off to get the paint on. Thanks booggerbe
