1 - 2 of 2 Posts
Before I pull my faring off, does anyone know if the blue high beam indicator light (mine is out) is replaceable? Is it an LED light. I did a search and can't come up with anything. The bike is an 06 FLHX...Thanks
repeat offender
Hey Reg
It's in the service manual on page 8-91. Says you remove the outer fairing and the tachometer to gain access to the bulb housing. There are 4 clips that secure the bulb housing to the lense that is mounted to the inner fairing. It doesn't say what type of bulb or what it cross references to. The wires that come out of the rear of the bulb housing run about 6 to 10 inches to a 10-place multi-lock connector.
Good Luck!
1 - 2 of 2 Posts
