1 - 2 of 2 Posts
I have a 98 FLSTC and while lubing my throttle cables some of the chain/cable lube I was using got on the cylinder heads and lifted the black texture paint. I noticed Harley sells the paint in aerosol form and was curious if there were any "need to know" tips that would assist me in repairing the damaged heads.
Clean Clean Clean
that paint works really well but the surface needs to be spotless. once you are all done super cleaning it I recomend using Brake Clean spray bomb. that will get in all the places you cant blow her off and put the black to her. ***TIP the thicker you apply the paint the more texture you get****
I used several light coats mached up to factory look Meat
1 - 2 of 2 Posts
