have an 06 train and i want to go up in risers with no bend... i want maybee 7 1/2 i really dont want 8 inch but if i have too i will i dont like bends in the risers... does anyone know wear i can git them also does anyone know if the cables with reach that extra inch and a half ?
The Anti-RUB
You can find them in most parts catalogs like Drag Specialties, J&P Cycles and Custom Chrome.
As for the cables fitting, they should. There is enough slack in the cables that you should be fine. One "quick" way to test is to take the bars out of the clamp and place them by hand where you want them to be after the riser change. If the cables are tight, or are hitting the tank, you'll need longer ones. If not, your good to go... Good luck...
Midnight Sporty, are you looking for a little bit more comfortable position, or just more height? If comfort is the key, Custom Chrome has a set of 6.5" rise with a 1" pullback. I put them on my bike, and it made a huge difference.
Don
