Not to pick nits, but it's actually the Overlap area, and this is determined as much by Lobe Separation Angle as it is by duration. Within the limits of mechanical interference, a big cam with lots of duration can still idle well if the LSA can be made wide enough. Conversely, a short cam with little duration will not idle so well with a narrow LSA. (Think S&S 561).The lope comes from long duration...
You want a little more lope? toss the EFI and bolt up a carb fuel leak to compliment the narrow LSA camshaftNot to pick nits, but it's actually the Overlap area, and this is determined as much by Lobe Separation Angle as it is by duration. Within the limits of mechanical interference, a big cam with lots of duration can still idle well if the LSA can be made wide enough. Conversely, a short cam with little duration will not idle so well with a narrow LSA. (Think S&S 561).
The duration number in and of itself is pretty meaningless. It's the event timing that counts.
As to idle lope: It's as much due to the style of intake manifold as anything else on a Harley. There's so much cross-talk going on in there it's a wonder they idle at all. Listen to a Marelli EFI bike compared to a Delphi EFI bike. Even with a much bigger cam the MM bike will idle better. Why? No intake crosstalk...
The more you learn, the more there is to learn. Keep askin'.
Thanks, no offense taken at all.Not to pick nits, but it's actually the Overlap area, and this is determined as much by Lobe Separation Angle as it is by duration. Within the limits of mechanical interference, a big cam with lots of duration can still idle well if the LSA can be made wide enough. Conversely, a short cam with little duration will not idle so well with a narrow LSA. (Think S&S 561).
