1 - 12 of 12 Posts
i saw a couple of Ebay adds for 95 big bore pistons and bored cylinders for ar ound 300 dollars . Anyone know aboutthese kits?
Set of take off cylinders $40, Bored to match pistons $120, SE cast pistons, $115...
It's a good deal for someone, I guess there are some gaskets necessary, maybe $30 so if the kit includes those, probably pretty good.... alot easier than the route I described above...
claydbal said:
depends on how the boring was done. and piston brand/ quality.
Exactly! the quality of the honing job makes a big difference in the outcome. Personally, if one of the really good guys charges $150 for a bore and hone versus an unknown or someone with less experience charges less, I'll pay the few extra bucks for the quality job, my dos centavos.
You mean like use a CNC lathe to bore the cylinder and finish with diamond hones?? Just giving you chit Tote.
By the way I took care of Jason with some parts that we had extra to help him out.
The bore job can be done cheap or done right!!! To bore cylinders with a torque plate and finish hone to each piston for a performance application is very important but if your throwing together a low compression touring bike you can get away with the cheap way.
yep, like that and a lot of measurements on the final hone to size.
yep, he called me and was REALLY appreciative! he said he was going to write you a nice big thank you note! Josh that is. ;) chit bounces back, ya know! hahahaha....!!!
Tote,
I like the way you think.
Regards
Cylinders
Here, we have always considered the ability to correctly bore and torque hone a set of cylinders, ground level, basic, engine building skills. Not hard to do it right, once you know how to do it right.
1 - 12 of 12 Posts
