8-Ball said:I just put on the KV85 wires from Magnecor. They have a very interesting write up on wires.
Who did you purchase the Magnecors from?
I got the SE's so I would have orange wires. That's the only advantage over stock. Either your plug fires or it don't, there is no performance gain. Any good wire will work so again, stock is as good as the rest.Paniolo said:I know some of them look really cool, and have often thought of getting them myself, but what do they do?
I ordered them directly from Magnecor.BaggerDad said:Who did you purchase the Magnecors from?
Read Post #4Paniolo said:I'm not being a smart ass, so pardon my ignorance here, but what up upgraded wires do?
Do they improve HP/TQ?
Get better milage?
Insulate the stereo from interference?
Are they more dependable?
No problem.LAF said:Running the TCFI and all I have heard on Harley's ECU being sensitive to wires, and that there is a point where it is minuscule effect from 8mm to 10mm, as bold as I got was the SE wires with the next coldest Autolite.
Most aftermarket wires reduce the resistance in the wire and offer more insulation. Reducing the resistance makes more voltage avaliable to fire the spark plug. As cylinder pressure rises so does the voltage requirement, not enough voltage, you get a miss. Higher voltage will also give you a hotter spark, that in turn will ignite imperfect a/f ratios a weaker spark wouldn't. Current will take the path of least resistance, that path could be from the wire to some place other than the plug if there is not enough insulation.Paniolo said:I'm not being a smart ass, so pardon my ignorance here, but what up upgraded wires do?
Get better milage?
Stock wires work just as well as those high dollar ones. Don't waste the money unless you just want the pretty colors.Mtclassic said:Who makes the best spark plug wires? any one try Sumax wires?
Maybe, but compare them on a dyno and you won't see a difference.... I checked 4 different sets and they all performed the same as the stock wires. If all the ignition system components are working properly, then more expensive wires won't make a difference.HD Tech said:Most aftermarket wires reduce the resistance in the wire and offer more insulation. Reducing the resistance makes more voltage avaliable to fire the spark plug. As cylinder pressure rises so does the voltage requirement, not enough voltage, you get a miss. Higher voltage will also give you a hotter spark, that in turn will ignite imperfect a/f ratios a weaker spark wouldn't. Current will take the path of least resistance, that path could be from the wire to some place other than the plug if there is not enough insulation.
