All righty then.........
shrike96 said:
I actually was not questioning the success of the kit really, was more wondering on the bearing since its a name i didn't reconize and i wanted to determine if S&S had switched bearings in the kit. Needed more of a clarifaction on that issue.
Although LAF has quite a valid point, I know it is not what you are after. In my line of work, bearings are cheap insurance, always go for the best.
Perhaps you will recognize some of the brands listed below - there are a lot of bearing cross reference sites online. I would be confident that the supplied bearing would be suitable and rated for the load it is subjected too.
Designation Manufacturer NSK RHP Basic Dimensions Type/PartNumberNote AuxiliaryPartNotes Designation E/A Designation E/A d D B or T
6004 *** 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004 KOYO 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004 NACHI 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004 NTN 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004 SKF 6004 E A 20 42 12 Single-row deep groove ball bearing, open type
6004-2NKE NACHI 6004VV E A 20 42 12 Single-row deep groove ball bearing, non-contact sealed type
6004-2NSE NACHI 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealed type
6004-2RS1 SKF 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealded type
6004-2Z SKF 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004.2RS KOYO 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealded type
6004.2RSR *** 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealed type
6004.2RU KOYO 6004VV E A 20 42 12 Single-row deep groove ball bearing, non-contact sealed type
6004.2ZR *** 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004E INA HR6004 A A 20 42 12 Single-row deep groove ball bearing, open type
6004H INA 6004-H- E A 20 42 12 Single-row deep groove ball bearing, open type
6004H 2RS INA 6004-H-DDU A A 20 42 12 Single-row deep groove ball bearing, contact sealed type
6004H 2Z INA 6004-H-ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004LLB NTN 6004VV E A 20 42 12 Single-row deep groove ball bearing, non-contact sealded type
6004LLU NTN 6004DDU E A 20 42 12 Single-row deep groove ball bearing, contact sealded type
6004N *** 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N KOYO 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N NACHI 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N NTN 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N SKF 6004N E 6004N A 20 42 12 Single-row deep groove ball bearing, with snap ring groove
6004N+SP42 *** 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004NR KOYO 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004NR NACHI 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004NR NTN 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004NR SKF 6004NR E A 20 42 12 Single-row deep groove ball bearing, with snap ring
6004ZZ KOYO 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004ZZ NTN 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
6004ZZE NACHI 6004ZZ E A 20 42 12 Single-row deep groove ball bearing, shielded type
