All the advice above is good, no problem with any of it.
For what it is worth, something to consider. Make sure your jets are all from the same company, whoever you choose. Reason is, a 190 from CV Performance, for example, might flow the same as a 185 Keihin or from a Harley Screamin Eagle jet kit. But generally a 190 CV performancde flows more than a 185 CVP, but less than 195 CVP. And so forth. I'm not saying the brands all flow different; I -am- saying that I do not know for sure, so best to be safe and take the easy way out. You may want to make other modifications and need another jet size or two to get it right, so get a couple different sizes just in case.
The only way to make sure of the flow is to flow test them and most of us can't due to lack of time, motivation, or flow test equipment. You will probably be OK using more than one brand, but just to be safe, you have to buy them anyway, so it is just as easy to get them all from the same place.
