Looking to add some to my motor a little at a time. Figure I will start with a cam change (geared) as well as add a Feuling pump and change out the inner cam bearings.
This is for a softail with a solo 250# rider. 50% around town, 50% fully loaded (saddlebags, t-bags, sometimes two-up) and going from sea level to 7000' on steep mountain highways. Rarely revs above 4500, usually shifted by 3500 rpm. Will probably punch out to 95" and maybe port heads someday.
I am looking for the lowest rpm I can get higher torque and still have a broad torque band. Must run pump fuel (sometimes 89 octane is all I find in the mountains) and run well at 90+ ambient temperature.
I have looked at the Andrews 26G and 37G and the Woods TW-6. Any suggestions?
Can the 37G be advanced to come on quicker like the 26G but still have the broader torque band? Does the Woods really pull from idle with an intake closing angle of 40 degrees? Are they Woods really noisy no matter what? With gear driven cams already I don't need yet more noise on top of it all.
I have a 2006, 88", SE/AC and V&H Pro Pipe with original torque baffle. Will be adding a PCIIIusb soon since stage 1 download works minimally, but is still too hot.
Thanks for any and all input guys!
