So...a little background : I pulled the motor out of my bagger 117ci and found a Dyna complete with a blown motor to install it in. After cleaning about 5oz of ground up rod bearing matter out of the oil pan of the dyna I managed to get the 117 motor installed in the frame. This dyna project is a secondary project as the reason I pulled the motor out of the bagger in the first place was to install a bigger motor in it. Thing is I don't have room to work on two bikes at the same time and have only one lift which the dyna is on right now so I'm trying to finish it off without spinding all my budget. The pipes that came with the dyna are bone stock and since I am trying to save $$ for the bagger I have decided to use the stock head pipes. I thought about just punching out the stock mufflers but first I thought I would ask for some ideas on a cheap way to go for mufflers...I hear that cycle shack has an inexpensive set of mufflers that make good power. They have so many sets on there site I was wondering if anybody has used there slip-ons and if so how do/did you like them. Any other ideas are welcome I just cant afford to spend much on the dyna right now.
