1 - 2 of 2 Posts
Buddy asked me to help him on his 03 sporster.Kinda of a lame question cause i've only woked on BIG TWINS and my V ROD.Is there an inner and outer primary on these bikes and do you have to disassemble them to replace the belt?My v rod you can change the belt in 2 seconds, on my buddies softail its a :whatever: bitch?How is it on the sporsters? ThanX Chris
Well, seeing as in you're in the softail section asking about a sportster, you may not get an answer.
But a sportster isn't a whole lot tougher than your vrod. There is no primary involved, as they are right side drive. Remove the cover, detension belt, remove lower bolt to shock.... done.
Oh, well, you may have to mess with the brake arm somewhat, but it's pretty obvious.
1 - 2 of 2 Posts
