mrsnipy said:I routed the cable down the right side of frame and wire tied it to frame just along side my oil fill cap on motor when it's not in use it tucks in there real nice.remove your frame side cover and wire tie it to the frame there also.
The power output of the Junior is less than the Plus. Go to www.batterytender.com, then the Technical Home section under Information. There is a FAQ there in addition to other info.Hoss said:What is the diff between the junior and the plus? and what does everyone recommend?
......Thanks Ed. I missed that VERY important spec in my haste to assist...Ed Y said:
GOODNESS!!! Where would we all be without your knowledge!??Under the seat there's a 3" hole just go thru that.
