Ok bud, here is the correct method, pull your spark plugs out before doing anything, make note of the color on the porcelain surrounding the center electrode, if it is white you are not getting enough fuel, if its black to much fuel, if its tan you are getting the correct amount of fuel. If you have stock jetts in your carb, change to a 46 intermediate jett for sea level. Do not mess with the main jett. More than likely if your carb is stock, your spark plugs will be bone white.
Go ride at hiway speed for 5 miles, pull spark plugs again, make note of color, if you have a tan color, you are good, white go up to a 47, black go to a 45 intermediate.
Good luck bud,
Tom @ LPCycles
btw, what year & model is your ride?
I just installed my Bassani Pro-Street pipes I got for Christmas and I need some help. I can feel a major loss of low end power. I have not rejetted the carb (still stock settings) and I do have the SE Air cleaner assembly. It almost feels like on take-off it is sputtering and running kind of rough. Is this a normal problem...how do I remedy it? This NEVER happened with my unbaffled longshots.
