Shiny bad. Black good.
All,
I have a flat profile chrome battery cover that I'd like to paint wrinkle black. However, I'd like to leave a small area of the chrome in the shape of a Maltese or Iron Cross for some flair. I'm trying to figure out a way to block off that cross shape on the cover so I can sand and paint around it, therefore leaving a chrome cross when I'm done. I thought about cutting an outline of it using a bunch of that blue painters tape, but, I'm not sure if that's the best way to go. Any suggestions?
Thanks in advance...
Whiffleboy
Whiffleboy said:
All,
Whiffleboy
Go to an automotive paint supply shop. get a roll of 3m protective tape . One application is like 10 of regular tape . Cut out your design then scuff the chrome withy a heavy scotchbrite pad (green?) hit it with a coat of adhesion promoter then paint it.. But paint dont stick all that great to chrome the only product that I have seen with any durability is from Alsa corp but its very pricey http://www.alsacorp.com/products/clear4chrome/cl4ch_prodinfo.htm.
$129 for a qt and 1/2 pint of catalyst is $29.
Another thought is to go to one of the sign shops that do sandblasted wood signs. They use a rubberized tape to get the raised letters . I dont see why they couldn't do the same on your chrome . this way u would have the chrome sandblasted off where you want to paint and it will last longer
Hi there,Fxsts is spot on with his first answer,but I would use 3m fine line tape on the outline of your cross.This ensures a nice fine edge when you remove the tape.Oh yeah, he is right when he says green scotchbrite.Hope this helps!Regards Mickey.
I think blasting is the way to go here. It would be much faster and give the paint a better [email protected]:
