It's really not that difficult. Here are some quick instructions for a Road King Classic:
1) Remove right side floorboard.
2) Remove right side hard bag.
3) Remove right side exhaust. (Note: It helps to spray the header flange bolts and muffler-to-header joint with a good "liquid penetrant" spray a couple of hours prior to disassembly.
4) Drain oil. Note: Not sure if this is required but I needed to change my oil anyway.
5) Remove cam cover. Note: Take care in removing cam cover screws! Mine had some type of Loctite on them and I had to work them in and out slowly until they turned freely.
6) Drive the existing roll pin out using a 1/8" pin punch. Note: Drive the roll pin out slowly and make sure you catch it when it comes out.
7) Take a small hook and pull the old spring out enough that you can roll it past the cam chain tensioner spring. Note: Getting the old spring out enough so you can spin it out can be tricky.
8) Install the new spring and roll pin. Note: It is much eaiser to have help on this step. Have one person hold the spring past the roll pin hole using a small screwdriver. The other person can drive the roll pin thru. I used a new roll pin and turned the split away from the spring.
9) Reassemble in reverse order. Note: Be extra careful while torquing the cam cover screws. It is very easy to crack your case or strip theads if you over-torque the screws. I used a quality torque wrench (Snap-On) and torqued to 95 in-lbs. using 4 passes in the order specified in the service manual. I started out at 25 in. lbs. first pass, 65 in. lbs. second pass, 95 in. lbs. third pass and check pass.
10) Don't forget to refill with oil!!!!!
This was posted a while back ( by jlight). Hope it helps! Clean out any oil that gets into the cam cover bolt holes with a Q-tip. If you leave oil in them the hydro lock can crack your case.
